[mapguide-users] authentication II
Juanita Juanita581 at riseup.net
Thu Jan 3 11:19:42 PST 2013
On 2013-01-03 02:37, Martin Morrison [via OSGeo.org] wrote:
>  Put "&user=Anonymous"  (might be username=) at the end of your url...
> Martin
> ________________________________
> From: [hidden email] </user/SendEmail.jtp?type=node&node=5025378&i=0>
> [[hidden email] </user/SendEmail.jtp?type=node&node=5025378&i=1>] on
> behalf of Juanita [[hidden email]
> </user/SendEmail.jtp?type=node&node=5025378&i=2>]
> Sent: Wednesday, January 02, 2013 3:03 PM
> To: [hidden email] </user/SendEmail.jtp?type=node&node=5025378&i=3>
> Subject: Re: [mapguide-users] authentication II
> On 2013-01-02 19:33, GordonL [via OSGeo.org] wrote:
> Are you using Microsoft IIS?  If so, check permissions.
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.n6.nabble.com/authentication-II-tp5025338p5025340.html
> To unsubscribe from authentication II, click here<UrlBlockedError.aspx>.
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> No I'm using MG 2.4 , Maestro 5b, Apache from installer. Gordon I’ll
> be thankful if You could check on your system, the authentication on
> similar address:
> http://<your_host>:8008/mapguide/fusion/templates/mapguide/aqua/index.html?ApplicationDefinition=Library://Layouts/<your<UrlBlockedError.aspx>
> name application>.ApplicationDefinition&locale=en
> I haven’t got anything just loaded the map on template but I need
> authentication
> required
> View this message in context: Re: authentication
> II<http://osgeo-org.1560.n6.nabble.com/authentication-II-tp5025338p5025352.html>
> Sent from the MapGuide Users mailing list
> archive<http://osgeo-org.1560.n6.nabble.com/MapGuide-Users-f4182607.html>
> at Nabble.com.
> mapguide-users mailing list
> [hidden email] </user/SendEmail.jtp?type=node&node=5025378&i=4>
> discussion below:
> http://osgeo-org.1560.n6.nabble.com/authentication-II-tp5025338p5025378.html
> <http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5025338&code=SnVhbml0YTU4MUByaXNldXAubmV0fDUwMjUzMzh8MzU4OTE3MjQx>.
> NAML
Didn’t work :(
I have to find solution through httpd.conf (by .htaccess and .htpasswd)
View this message in context: http://osgeo-org.1560.n6.nabble.com/authentication-II-tp5025338p5025533.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130103/8573a520/attachment.html>
