[mapguide-users] Download extention php mapguide for fedora 17 64bit
HUE Christophe
chue at ubiqus.com
Fri Jan 11 07:28:05 PST 2013
thank,
I tried to compile only those extensions WEB (MgDev /Web/src/PhpApi)
For this compilation I compiled imake, swig, php / Zend dbxmk, Geos and
MgDev libs / Common.
I still have an error in compiling MgDev/Common/Geometry
I compiled Oem/CsMap (Oem/CsMap/.libs/libCsmap.a) and the make of
MgDev/Common/Geometry I found this error:
/ usr / bin / ld: cannot find-lMgFoundation
/ usr / bin / ld: .. /.. / Oem / CsMap / .libs / libCsmap.a (CS_ansi.o):
relocation R_X86_64_32S against `. bss' can not be used When making a shared
object; recompile with-fPIC
.. /.. / Oem / CsMap / .libs / libCsmap.a: could not read symbols: Bad value
Can you help me?
FYI, here is the compilation of CsMap:
mkdir-p. libs
Source cd
make-fLibrary.mak
CsMap.a cp .. / .libs / libCsmap.a
cd .. / Dictionaries
make-fCompiler.mak
. / CS_Comp-b. .
-----Message d'origine-----
De : mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] De la part de Jackie Ng
Envoyé : jeudi 10 janvier 2013 13:33
À : mapguide-users at lists.osgeo.org
Objet : Re: [mapguide-users] Download extention php mapguide for fedora 17
64bit
dlls are *Windows* binaries
There is currently no 64-bit linux builds of MapGuide available.
- Jackie
View this message in context:
http://osgeo-org.1560.n6.nabble.com/Download-extention-php-mapguide-for-fedo
ra-17-64bit-tp5026610p5026628.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
CONFIDENTIALITY NOTICE - The information contained in this message and any accompanying documents may be privileged and confidential and protected from disclosure. If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us immediately by replying to the message and deleting it from your computer. Thank you.
NOTE DE CONFIDENTIALITE - Ce message et toutes les pieces jointes (ci-apres le "message") sont etablis a l'intention exclusive de ses destinataires et sont confidentiels. Si vous recevez ce message par erreur, merci de le detruire et d'en avertir immediatement l'expediteur. Toute utilisation de ce message non conforme a sa destination, toute diffusion ou toute publication, totale ou partielle, est interdite, sauf autorisation expresse. L'internet ne permettant pas d'assurer l'integrite de ce message, Ubiqus (et ses filiales) decline(nt) toute responsabilite au titre de ce message, dans l'hypothese ou il aurait ete modifie.
