[mapguide-users] authentication II
Juanita Juanita581 at riseup.net
Wed Jan 16 09:20:26 PST 2013
Hi mpozauko,
Open MG Maestro (my settings: MG 2.4, Maestro 5b5)
1.	Click on your fusion application on the catalog list (right key )
2.	You see this (below):
<http://osgeo-org.1560.n6.nabble.com/file/n5027891/Maestro_XML_authentication.jpg>
3.	Click: Edit Raw header XML and change access only to group or user, using
XML script. Scripts You have in my previous post, than You should get
Authentication Required window (exactly the same like this on the top of
this tread)
View this message in context: http://osgeo-org.1560.n6.nabble.com/authentication-II-tp5025338p5027891.html
