[mapguide-users] WMS from MGOS can't be read by QGIS
Rémy Gourrat
rgourrat at ag-carto.fr
Fri Jan 25 08:37:38 PST 2013
Hum…
1 question :
- Have you tried to consume wms service on a sheboygan layer ? In general it’s running first and easy…
2 remarks because i don’t have any idea… :
- I see in you URL mapserver2013, you are sure that it’s MapGuide Open Source ? it’s not Autoudesk Infrastructure MapServer ? if yes have you installed your MapGuide OSE on AIMS ?
- When you ask VERSION=1.3.0 in your URL you have ServiceExceptionReport version="1.3.0" but when you ask VERSION=1.1, mapguide return ServiceExceptionReport version="1.0.0"
Can you send a clipboard of your wms config panel under mapguide/mapadmin/login.php ?
Rémy
De : Franz1965 [via OSGeo.org] [mailto:ml-node+s1560n5029907h70 at n6.nabble.com]
Envoyé : vendredi 25 janvier 2013 17:26
À : Rémy GOURRAT
Objet : RE: WMS from MGOS can't be read by QGIS
Rémy Gourrat wrote
Have you try to inspect qgis wms query with Fiddler ?
Hi Rémy,
great suggestion! Fiddler with QGis is very interesting, something new I've learned today, good :).
I've done what you've suggeted and I've got the following:
When QGis execute:
http://localhost/mapserver2013/mapagent/mapagent.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=671401.028954,75246.995246,734864.771170,165663.792311&CRS=EPSG:21781&WIDTH=32&HEIGHT=32&LAYERS=WMS-WFS/Common/Layers/LayerDefinitionSHPComuni&STYLES=&FORMAT=image/png&TRANSPARENT=TRUE HTTP/1.1
I get:
<?xml version="1.0" encoding="UTF-8" ?>
- <ServiceExceptionReport version="1.3.0" xmlns="http://www.opengis.net/ogc"<http://www.opengis.net/ogc%22> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"<http://www.w3.org/2001/XMLSchema-instance%22> xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd"><http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd%22%3e>
<ServiceException code="InternalError">Unexpected exception was thrown. No additional details available.</ServiceException>
</ServiceExceptionReport>
If I change version to 1.1:
http://localhost/mapserver2013/mapagent/mapagent.fcgi?SERVICE=WMS&VERSION=1.1&REQUEST=GetMap&BBOX=671401.028954,75246.995246,734864.771170,165663.792311&CRS=EPSG:21781&WIDTH=32&HEIGHT=32&LAYERS=WMS-WFS/Common/Layers/LayerDefinitionSHPComuni&STYLES=&FORMAT=image/png&TRANSPARENT=TRUE HTTP/1.1
- <ServiceExceptionReport version="1.0.0">
The result is more or less the same :(
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.n6.nabble.com/WMS-from-MGOS-can-t-be-read-by-QGIS-tp5029828p5029907.html
To start a new topic under MapGuide Users, email ml-node+s1560n4182607h70 at n6.nabble.com<mailto:ml-node+s1560n4182607h70 at n6.nabble.com>
To unsubscribe from MapGuide Users, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4182607&code=cmdvdXJyYXRAYWctY2FydG8uZnJ8NDE4MjYwN3w1MzYwNTE3NDA=>.
NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
AG-Carto - Bayonne
View this message in context: http://osgeo-org.1560.n6.nabble.com/WMS-from-MGOS-can-t-be-read-by-QGIS-tp5029828p5029911.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130125/826a1df2/attachment.html>
