[mapguide-users] WMS from MGOS can't be read by QGIS
Franz1965 fsozzi at INTERCAD.CH
Fri Jan 25 09:03:55 PST 2013
Rémy Gourrat wrote
> Have you tried to consume wms service on a sheboygan layer ? In general
> it’s running first and easy…
At the moment I haven't this sample. I will install it and test...
Rémy Gourrat wrote
> I see in you URL mapserver2013, you are sure that it’s MapGuide Open
> Source ? it’s not Autoudesk Infrastructure MapServer ? if yes have you
> installed your MapGuide OSE on AIMS  ?
Yes, this is AIMS. I'm doing the same test (with the same results) on:
- server 2008 / MGOS
- virtual machine Windows 7 64 bit MGOS
- virtual machine Windows 7 64 bit AIMS
Your test comes from AIMS, but I get the same result from my MGOS server:
http://213.133.229.149/mapguide/mapagent/mapagent.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=671401.028954,75246.995246,734864.771170,165663.792311&CRS=EPSG:21781&WIDTH=32&HEIGHT=32&LAYERS=WMS-WFS/Common/Layers/LayerDefinitionSHPComuni&STYLES=&FORMAT=image/png&TRANSPARENT=TRUE
HTTP/1.1
  <?xml version="1.0" encoding="UTF-8" ?>
- <ServiceExceptionReport version="1.3.0" xmlns="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/ogc
http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd">
  <ServiceException code="InternalError">Unexpected exception was thrown. No
additional details available.</ServiceException>
  </ServiceExceptionReport>
http://213.133.229.149/mapguide/mapagent/mapagent.fcgi?SERVICE=WMS&VERSION=1.1&REQUEST=GetMap&BBOX=671401.028954,75246.995246,734864.771170,165663.792311&CRS=EPSG:21781&WIDTH=32&HEIGHT=32&LAYERS=WMS-WFS/Common/Layers/LayerDefinitionSHPComuni&STYLES=&FORMAT=image/png&TRANSPARENT=TRUE
HTTP/1.1
- <ServiceExceptionReport version="1.0.0">
<http://osgeo-org.1560.n6.nabble.com/file/n5029924/wms_config.png>
View this message in context: http://osgeo-org.1560.n6.nabble.com/WMS-from-MGOS-can-t-be-read-by-QGIS-tp5029828p5029924.html
