[mapguide-users] Unable to load postgis feature source
Smith Roman autisi at yahoo.com
Sat Jan 26 02:26:21 PST 2013
I am unable to access postgis database using map maestro 5. I am using postgres 8.4 and postgis 1.5.2. Map guide 2.4.
Cheers,
Smith.
Here is the log:
The remote server returned an error: (559) MgFdoException.:
An exception occurred in FDO component.
Unable to load the FDO Provider library '.\PostgreSQLProvider.dll': The specified module could not be found.
  (Cause: , Root Cause: Unable to load the FDO Provider library '.\PostgreSQLProvider.dll': The specified module could not be found.
System.Exception: The remote server returned an error: (559) MgFdoException.:
 ---> System.Net.WebException: The remote server returned an error: (559) MgFdoException.
   at System.Net.HttpWebRequest.GetResponse()
   at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead(String req) in c:\Program Files (x86)\Jenkins\jobs\Maestro trunk\workspace\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line 1310
   --- End of inner exception stack trace ---
   at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead(String req) in c:\Program Files (x86)\Jenkins\jobs\Maestro trunk\workspace\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line 1326
   at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.GetProviderCapabilities(String provider) in c:\Program Files (x86)\Jenkins\jobs\Maestro trunk\workspace\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line 1751
   at Maestro.Base.Editor.FsEditorOptionPanel.Bind(IEditorService service) in c:\Program Files (x86)\Jenkins\jobs\Maestro trunk\workspace\Maestro.Base\Editor\FsEditorOptionPanel.cs:line 60
   at Maestro.Base.Editor.FeatureSourceEditor.Bind(IEditorService service) in c:\Program Files (x86)\Jenkins\jobs\Maestro trunk\workspace\Maestro.Base\Editor\FeatureSourceEditor.cs:line 63
   at Maestro.Base.Editor.EditorContentBase.set_EditorService(IEditorService value) in c:\Program Files (x86)\Jenkins\jobs\Maestro trunk\workspace\Maestro.Base\Editor\EditorContentBase.cs:line 110
   at Maestro.Base.Services.OpenResourceManager.Open(IResource res, IServerConnection conn, Boolean useXmlEditor, ISiteExplorer siteExp) in c:\Program Files (x86)\Jenkins\jobs\Maestro trunk\workspace\Maestro.Base\Services\OpenResourceManager.cs:line 191
   at Maestro.Base.Services.OpenResourceManager.Open(String resourceId, IServerConnection conn, Boolean useXmlEditor, ISiteExplorer siteExp) in c:\Program Files (x86)\Jenkins\jobs\Maestro trunk\workspace\Maestro.Base\Services\OpenResourceManager.cs:line 259
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130126/35fe0dc3/attachment.html>
