[mapguide-users] Unable to load postgis feature source
Smith Roman
autisi at yahoo.com
Wed Jan 30 10:01:11 PST 2013
Hi Steve,
I have verified the 3 points you listed and all seems to be okay. Still yet to figure out where the problem is coming from.
Regards,
To: mapguide-users at lists.osgeo.org
Sent: Monday, January 28, 2013 10:37 PM
Subject: Re: [mapguide-users] Unable to load postgis feature source
Perhaps a few things to check:
1. Check out the FDO folder where the dll's are installed (typically folder
location, C:\Program Files\OSGeo\MapGuide\Server\Fdo). Is the
PostgreSQLProvider.dll file there? Also check providers.xml to see that the
provider is listed. You should find the following:
<FeatureProvider>
<Name>OSGeo.PostgreSQL.3.7</Name>
<DisplayName>PostgreSQL/PostGIS Provider</DisplayName>
<Description>Read/write access to PostgreSQL/PostGIS-based data store.
Supports spatial data types and spatial query operations.</Description>
<IsManaged>False</IsManaged>
<Version>3.7.0.0</Version>
<FeatureDataObjectsVersion>3.7.0.0</FeatureDataObjectsVersion>
<LibraryPath>.\PostgreSQLProvider.dll</LibraryPath>
</FeatureProvider>
2. Check out these notes:
http://trac.osgeo.org/fdo/wiki/FdoPostgreSQLNotes
3. Your problem may also be the bit-ness of your install (64 bit vs. 32).
See the following thread for info.
http://osgeo-org.1560.n6.nabble.com/FDO-PostgreSQL-PostGIS-provider-on-64bit-td4183551.html#a4183555
View this message in context: http://osgeo-org.1560.n6.nabble.com/Unable-to-load-postgis-feature-source-tp5030025p5030340.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130130/758e4382/attachment.html>
