[mapguide-users] Problem using Filter on Layer
Jérôme DUCKERS jerome.duckers at gmail.com
Thu Jan 31 23:58:44 PST 2013
So, as Remy said, you can use only contenido in the tooltip, and see if
it's different.
2013/2/1 naish666 <naish666 at msn.com>
> The "tipo" of the tooltip it is no the same as the "tipo" (now rename to
> "tip") of the table. The "tipo" of tooltip must be always 1. The main
> variable on tooltip is "contenido".
> http://osgeo-org.1560.n6.nabble.com/Problem-using-Filter-on-Layer-tp5028966p5031419.html
>  Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130201/f41b99f8/attachment.html>
