[mapguide-users] Re-thinking Fusion redlining efficiency
Rich Bauer rdbauer at gmail.com
Wed Jul 10 07:14:15 PDT 2013
I don't have any thoughts on how to do this, but I do think it would be a
great feature. It would also make it easier to "go offline" and still use
this widget and just commit back when you go back online. I am not
intimately familiar yet with the widget, but since you would be using
OpenLayers, couldn't you just pass the style that you want to that
Layer.Vector and still have a "custom" style?
On Tue, Jul 9, 2013 at 9:34 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Hi All,
> I've been thinking about the efficiency of drawing redlines in Fusion.
> While
> we've eliminated most of the workflow slowness in the data store and layer
> setup before you even get to start drawing your lines and squiggles, the
> actual drawing process still seems woefully inefficient where each geometry
> drawn triggers a map refresh. For really heavy maps, redlining against them
> seems to be very inefficient
> I'm starting to float the idea of a client-side "staging area" for newly
> drawn redlines.
> The idea is that when you draw your redlines they don't immediately get
> saved to your redline SDF/SHP/SQLite feature source server-side, instead
> they are stored client-side in a OpenLayers.Layer.Vector. This would then
> allow the user to draw multiple objects rapidly in succession without
> interruptions from map refreshes. When they're done, the user can then
> commit and save the whole lot of client-side redlines into the redline
> SDF/SHP/SQLite feature source in one go and then the widget can trigger a
> map refresh.
> So the process for drawing 5 redlines is currently:
>  * Invoke Redline widget
>  * Choose redline data store type (in Fusion trunk, this option can be
> shortcutted thus skipping this step)
>  * Draw redline #1 -> Triggers map refresh
>  * Draw redline #2 -> Triggers map refresh
>  * Draw redline #3 -> Triggers map refresh
>  * Draw redline #4 -> Triggers map refresh
>  * Draw redline #5 -> Triggers map refresh
> The process of drawing 5 redlines under this theoretical revised widget
> would look like this.
>  * Draw redline #1
>  * Draw redline #2
>  * Draw redline #3
>  * Draw redline #4
>  * Draw redline #5
>  * Review what you've drawn.
>    * If everything's ok, commit and save the lot and trigger map refresh.
>    * If something's wrong, discard/edit the client-side vector objects and
> commit.
> The revised widget would cut down the amount of map refreshes, with the
> small caveat that redlines in the "staging area" won't have your configured
> redline styles (they'll be using whatever OpenLayers provides) and they
> won't show up in any plots of the map until they've been committed by the
> user.
> Thoughts?
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/Re-thinking-Fusion-redlining-efficiency-tp5065272.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130710/5f441078/attachment.html>
