[mapguide-users] 64 bit version for Linux
Kyel kyel at quamdesigns.com
Thu Jul 11 12:57:48 PDT 2013
I was wondering if any workarounds were discovered to compile FDO as 32-bit
during the testing phases on 2.5.0 during January/February 2013 to build
source code on CentOS.
The common ELF CLASS errors appear after using the build scripts as is (i.e.
compiling in 64-bit).  I modified build_thirdparty.sh and build_linux.sh to
use './configure CPPFLAGS=-m32 LDFLAGS=-m32' but that failed to create
libFDO-3.8.0.so altogether.  The goal is to add external FDO Providers to
the standard CentOS tarball package install (which works great on the same
64-bit system).
View this message in context: http://osgeo-org.1560.x6.nabble.com/64-bit-version-for-Linux-tp5064699p5065868.html
