[mapguide-users] SQL Spatial on MGOS 2.5
Rich Bauer rdbauer at gmail.com
Tue Jul 16 06:27:31 PDT 2013
I was wondering if that might be the case. Finally, after several updates
on vista and a service pack, I got the Native client installed and all
works as expected. Thanks for the info Jackie.
Rich
On Mon, Jul 15, 2013 at 8:15 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> The FDO provider for MGOS 2.2 internally used the out-of-the-box SQL Server
> ODBC driver, which is why this error never occurred.
> It is now internally using the SQL Server Native Client ODBC driver so the
> FDO provider can work with bigger geometries.
> You should install the SQL Server Native client on the machine where the
> MapGuide Server is installed, as that is where it is trying to make the FDO
> connection from.
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/SQL-Spatial-on-MGOS-2-5-tp5066541p5066622.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130716/52c9562b/attachment.html>
