[mapguide-users] SQL Spatial on MGOS 2.5
Jackie Ng
jumpinjackie at gmail.com
Mon Jul 15 18:15:28 PDT 2013
The FDO provider for MGOS 2.2 internally used the out-of-the-box SQL Server
ODBC driver, which is why this error never occurred.
It is now internally using the SQL Server Native Client ODBC driver so the
FDO provider can work with bigger geometries.
You should install the SQL Server Native client on the machine where the
MapGuide Server is installed, as that is where it is trying to make the FDO
connection from.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/SQL-Spatial-on-MGOS-2-5-tp5066541p5066622.html
