[mapguide-users] Selection of Layers Not Visible (Suggestions)
ChrisGo
cgountanis at mpowerinnovations.com
Fri Jul 19 07:04:19 PDT 2013
Couple of questions:
1. What is the best way to set the current map to allow selections on layers
that are not yet shown at a current scale?
2. Can this setting be set in the WebLayout of the map because that would be
awesome if you could set it via API or globally per map without having to
use FCGI call.
Please any information on the best usage for this would be great. Example: a
layer is not yet turned on and a user draws a selection box. I want all
layers within that selection box to be selected no matter if the layer is
visible or not.
I don't mind JS override but I really do not want to edit the viewer code is
possible.
HOW?
Thanks,
Chris
View this message in context: http://osgeo-org.1560.x6.nabble.com/Selection-of-Layers-Not-Visible-Suggestions-tp5067613.html
