[mapguide-users] MapGuide offline mode
Rich Bauer rdbauer at gmail.com
Tue Jul 30 06:12:12 PDT 2013
I just had another thought. I read Jackie's post about mapguide4j (
http://themapguyde.blogspot.com/2013/07/about-that-as-yet-un-announced-project.html)
and was wondering if this might be a possibility for wrapping it all up in
an app and deploying it with the UI? I don't know any of the details about
this as I just read it last night, so I might be totally off on what it is.
On Tue, Jul 30, 2013 at 8:06 AM, Rich Bauer <rdbauer at gmail.com> wrote:
> Thanks for the response Jackie.
> I do want to be able to "select" a parcel or etc. but it doesn't have to
> be rendered as a vector. After reading your response and trying to go to
> sleep last night, I was thinking about trying to use the tiles with
> OpenLayers Cache and do a select using like a xml file or something while
> in offline mode. If I knew Java, then I would be up for trying to port your
> MgDesktop to Java, but that is beyond my capabilities right now. I will try
> to post back to let everyone know what I end-up with.
> Rich
> On Tue, Jul 30, 2013 at 12:31 AM, Jackie Ng <jumpinjackie at gmail.com>wrote:
>> If someone has figured this out, we would've known about it by now :)
>> Do you want offline tiled maps? Raw OpenLayers + CacheRead/CacheWrite
>> controls can already do this, though you'll have to mod
>> to access something other than the default HTML5 local storage with its
>> pitiful 5MB storage limit. Such an approach would require an explicit tile
>> seeding function of some sort so you can "take your map offline"
>> Do you want offline vector maps? We have the means of local storage
>> (WebSQL/IndexedDB), but not the means to render vectors client-side.
>> OpenLayers and Leaflet can probably do this to some degree, but you lose
>> styling fidelity as rendering is now the responsibility of OL/Leaflet. I
>> don't know if OL/Leaflet can handle big datasets yet as all their vector
>> examples involve sub-200 vector datasets (eg. Countries of the world and
>> other simple datasets). OpenLayers 3 is supposed to be able to do this.
>> There's probably other options, but they haven't been fully explored.
>> - Jackie
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/MapGuide-offline-mode-tp5069523p5069524.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130730/846d388c/attachment.html>
