[mapguide-users] MapGuide offline mode
Rich Bauer rdbauer at gmail.com
Tue Jul 30 06:06:55 PDT 2013
Thanks for the response Jackie.
I do want to be able to "select" a parcel or etc. but it doesn't have to be
rendered as a vector. After reading your response and trying to go to sleep
last night, I was thinking about trying to use the tiles with OpenLayers
Cache and do a select using like a xml file or something while in offline
mode. If I knew Java, then I would be up for trying to port your MgDesktop
to Java, but that is beyond my capabilities right now. I will try to post
back to let everyone know what I end-up with.
Rich
On Tue, Jul 30, 2013 at 12:31 AM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> If someone has figured this out, we would've known about it by now :)
> Do you want offline tiled maps? Raw OpenLayers + CacheRead/CacheWrite
> controls can already do this, though you'll have to mod
> to access something other than the default HTML5 local storage with its
> pitiful 5MB storage limit. Such an approach would require an explicit tile
> seeding function of some sort so you can "take your map offline"
> Do you want offline vector maps? We have the means of local storage
> (WebSQL/IndexedDB), but not the means to render vectors client-side.
> OpenLayers and Leaflet can probably do this to some degree, but you lose
> styling fidelity as rendering is now the responsibility of OL/Leaflet. I
> don't know if OL/Leaflet can handle big datasets yet as all their vector
> examples involve sub-200 vector datasets (eg. Countries of the world and
> other simple datasets). OpenLayers 3 is supposed to be able to do this.
> There's probably other options, but they haven't been fully explored.
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/MapGuide-offline-mode-tp5069523p5069524.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130730/2e178f94/attachment.html>
