[mapguide-users] Select specific layer and feature by passing value to flexible layout (AIMS2014)
RenoSun renolionheart at gmail.com
Sun Jun 2 13:28:11 PDT 2013
Hello Gordon,
Thank you for answering. You said you use JavaScript to pass parameters such
as  MAPNAME, SESSION, LAYER, KEYNAME and KEY to a PHP to get the selected
XML.
Would you please tell me what the php name is? Is it search.php or
setselection.php? and Didn't you need to pass the filter/spatialfilter value
such as "FeatId = 1" to that php page? or Is the KEYNAME field name, and KEY
is field value?
Did you use ajax technique to get the selected XML response from the php
page?
By the way, would you mind to post more detailed code on this discussion?
Thank you very much!!!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Select-specific-layer-and-feature-by-passing-value-to-flexible-layout-AIMS2014-tp5055669p5057375.html
