[mapguide-users] Select specific layer and feature by passing value to flexible layout (AIMS2014)
GordonL
gordon.luckett at arrowgeomatics.com
Mon Jun 3 07:34:52 PDT 2013
How you get the KEY, LAYERNAME, KEYNAME is up to you.
You probably know that already. Just look at your SDF and your Layer Name.
Yes, I use AJAX to call the PHP and get the XML.
You can use this PHP...or tweak it a little and create your own.
C:\Program
Files\OSGeo\MapGuide\Web\www\fusion\widgets\FeatureInspector\GetSelectionXML.php
View this message in context: http://osgeo-org.1560.x6.nabble.com/Select-specific-layer-and-feature-by-passing-value-to-flexible-layout-AIMS2014-tp5055669p5057495.html
