[mapguide-users] Select specific layer and feature by passing value to flexible layout (AIMS2014)
RenoSun renolionheart at gmail.com
Wed Jun 5 10:10:11 PDT 2013
Hello GordonL,
I added following codes in the my fusionInitialized() function in fusion
var fusionInitialized = function () {
            $('AppContainer').resize({ forceResize: true });
            var mapWidget = Fusion.getMapById('Map');
            mapWidget.registerForEvent(Fusion.Event.MAP_LOADED,
initPanelHandler);
var sessionid = getMapGuideSessionID(mapWidget);
var mapname = getMapGuideMapName(mapWidget);
var link =
"http://10.10.200.104/mapserver2014/fusion/widgets/FeatureInspector/GetSelectionXML2.php?SESSION="
+ sessionid + "&MAPNAME=" + mapname;
//alert(link);
if (window.XMLHttpRequest) {// code for IE7+, Firefox, Chrome, Opera, Safari
xmlhttp = new XMLHttpRequest();
else {// code for IE6, IE5
xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
xmlhttp.onreadystatechange = function () {
if (xmlhttp.readyState == 4 && xmlhttp.status == 200) {
var selectionXml = xmlhttp.responseText;
//alert(selectionXml);
if (mapWidget && mapWidget.isMapLoaded()) {
xmlhttp.open("GET","http://10.10.200.104/mapserver2014/fusion/widgets/FeatureInspector/GetSelectionXML2.php?SESSION="
+ sessionid + "&MAPNAME=" + mapname, true);
xmlhttp.send();
Also, I added a new php in C:\Program Files\Autodesk\Autodesk Infrastructure
Web Server Extension 2014\www\fusion\widgets\FeatureInspector folder, and
the content is from the website you mentioned.
The content of php is following...
 <?php
  include('../../layers/MapGuide/php/Common.php');
  $args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST : $_GET;
  $sessionId = $args['SESSION'];
  $mapName = $args['MAPNAME'];
  try
    // Initialize the Web Extensions and connect to the Server
    // using the Web Extensions session identifier
    MgInitializeWebTier ($webconfigFilePath);
    $userInfo = new MgUserInformation($sessionId);
    $siteConnection = new MgSiteConnection();
    $siteConnection->Open($userInfo);
    $map = new MgMap($siteConnection);
    $map->Open($mapName);
    // Get the geometry for the parcel of FeatId equal to 2665
    $parcelQuery = new MgFeatureQueryOptions();
    $parcelQuery->SetFilter("FeatId = 2665");
    $layer = $map->GetLayers()->GetItem('QBParcels');
    $featureReader = $layer->SelectFeatures($parcelQuery);
    $featureReader->ReadNext();
    $parcelGeometryData = $featureReader->GetGeometry('Data');
    // Convert the AGF binary data to MgGeometry.
    $agfReaderWriter = new MgAgfReaderWriter();
    $parcelGeometry =
      $agfReaderWriter->Read($parcelGeometryData);
    // Create a filter to select the desired features. Combine
    // a basic filter and a spatial filter.
    $queryOptions = new MgFeatureQueryOptions();
    $queryOptions->SetFilter("FeatId = 2665");
    $queryOptions->SetSpatialFilter('Geometry', $parcelGeometry,
MgFeatureSpatialOperations::Inside);
    // Get the features from the feature source,
    // turn it into a selection, then save the selection as XML.
    $featureReader = $layer->SelectFeatures($queryOptions);
    $selection = new MgSelection($map);
    $selection->AddFeatures($layer, $featureReader, 0);
    $selectionXml = $selection->ToXml();
    echo $selectionXml;
  catch (MgException $e)
    echo $e->GetMessage();
    echo $e->GetDetails();
However, I can get the sessionid, but I cannot get the mapname. You
mentioned about that I should call the php until the map is loaded. Would
you please tell me where should I put my code?
Also, did you know what the 'Data' is in the php code? Is it also geometry
field name?
Thank you very much.
Sincerely,
Reno
View this message in context: http://osgeo-org.1560.x6.nabble.com/Select-specific-layer-and-feature-by-passing-value-to-flexible-layout-AIMS2014-tp5055669p5058197.html
