[mapguide-users] Infrastructure Map Server 2013 and Mapguide Open Source 2.1
Jackie Ng
jumpinjackie at gmail.com
Wed Jun 5 03:33:34 PDT 2013
You have to make sure that MGOS and AIMS are using different port numbers in
serverconfig.ini and webconfig.ini
If you're using IIS configuration for both you also have to make sure that
MGOS doesn't accidentally use AIMS' PHP or vice versa.
Everything else should be fairly well separated.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Infrastructure-Map-Server-2013-and-Mapguide-Open-Source-2-1-tp5058071p5058087.html
