[mapguide-users] Mapgiude OS Mobile Viewer
Srecko Lipovsek
srecko.lipovsek at kaliopa.si
Fri Jun 7 04:45:16 PDT 2013
Hi Stuart,
Actually Layer visibility depends on Scale Ranges and current scale, so I should rewrite jqueryLayerTree.aspx to check this parameter to and return only layers that are visible at specific scale ...
This is a little of extra work. I will create new file jqueryLayerTree.aspx and let you know in short ...
Thanks ...
Srecko L.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapgiude-OS-Mobile-Viewer-tp4941633p5058688.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130607/23a63403/attachment.html>
