[mapguide-users] Two map-definitions in one Fusion application definition not working properly
martin ju majirku at gis-services.sk
Mon Jun 17 01:12:20 PDT 2013
I am using MapGuide OS 2.4 with fusion, particularly slate template.
I have one fusion application definition. In this application definition I
add into "currently available maps" 2 map definitions:
  - One for slower view, but with more possibilities to turn off/on
different layers and layers groups...
  - One for fast viewing with tiling on, same layers as in first map
definition were grouped basically into 3 base layer groups...
Both map definitions are in same coordinate system.
I am using MapMenu widget to "switch" map definition. Fast map definition is
loaded on the beginning. When I switch to second one, it is not working
properly.
  - moving, selection or zoom in/out with a mouse wheel is not working until
I press "Refresh" widget, or another zoom widget.
  - Tiles from fast map definition are still being updated, and were not
turned off after switching.
  - In the slate template, after a change, Task Panel is maximized and then
it is hiding Panel with a legend
The MapMenu widget is defined this way:
<?xml version="1.0"?>
<WidgetType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:type="UiWidgetType">
  <Name>MapMenu</Name>
  <Type>MapMenu</Type>
  <Location />
  <Extension>
    <Folder />
  </Extension>
  <ImageUrl />
  <ImageClass />
  <Label>Map Menu</Label>
  <Tooltip>Choose your map</Tooltip>
  <StatusText />
  <Disabled>false</Disabled>
</WidgetType>
Any suggestions what's wrong?
Martin Jirku
 Web: it.jirku.sk
 Blog: map-gis.blogspot.com
View this message in context: http://osgeo-org.1560.x6.nabble.com/Two-map-definitions-in-one-Fusion-application-definition-not-working-properly-tp5060523.html
