[mapguide-users] Remove Map Overview window
Laura Kauria
lacation at gmail.com
Mon Jun 17 22:47:12 PDT 2013
Yes, this was an easy cake with your instructions! Cheers,
Laura
2013/6/13 Jackie Ng <jumpinjackie at gmail.com>
> It seems all the Fusion templates assume a Overview Map widget present even
> if you don't use it.
> For Aqua, if you just want to hide that window on a global template level
> (the easiest solution), just comment out this line
> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Oem/fusionMG/templates/mapguide/aqua/index.html#L47
> in the index.html of the aqua template.
> Hope that helps.
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/Remove-Map-Overview-window-tp5059942p5059952.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130618/d4503c07/attachment.html>
