[mapguide-users] Remove Map Overview window
Jackie Ng
jumpinjackie at gmail.com
Thu Jun 13 06:51:52 PDT 2013
It seems all the Fusion templates assume a Overview Map widget present even
if you don't use it.
For Aqua, if you just want to hide that window on a global template level
(the easiest solution), just comment out this line
(http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Oem/fusionMG/templates/mapguide/aqua/index.html#L47)
in the index.html of the aqua template.
Hope that helps.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Remove-Map-Overview-window-tp5059942p5059952.html
