[mapguide-users] Problem with access
Jackie Ng
jumpinjackie at gmail.com
Wed Jun 19 23:42:17 PDT 2013
How are you connecting? Via connection string or DSN?
You have to make sure all the bitness lines up. ie. For a 64-bit MapGuide
install:
* You have Access 2010 64-bit drivers installed
* If using connection strings, you are using the Microsoft Access 2010
driver ({Microsoft Access Driver (*.mdb, *.accdb)} and not {Microsoft Access
Driver (*.mdb)})
* If using DSNs, you created your DSN with the correct odbcad32.exe (On
64-bit windows, the one under C:\Windows\System32 is 64-bit, the one under
C:\Windows\SysWow64 is 32-bit). Yes, very intuitive locations!
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-access-tp5061262p5061266.html
