[mapguide-users] Compile Error: An attempt was made to load a program with an incorrect format.
frosty1_4me kbowman at cityofgp.com
Mon Jun 24 15:19:11 PDT 2013
I'm experiencing this issue with a Win 8, 64bit machine running VS 2012, with
a AIMS 2014 build.   I've tried everything that is listed in here with no
luck.  And since my app is a .Net 4.0 application I can't not compile it as
such so my application pool on the local IIS is v4.0.
The error is:
Could not load file or assembly 'MapGuideDotNetApi' or one of its
dependencies. An attempt was made to load a program with an incorrect
format.
>From everything I can find that's a 32bit dll issue, even thought I'm
running the 64bit install of AIMS and using the 64bit dlls for both the
local build of the web application as well as the Map server.
Is there any fix for this?  building a .Net app without the ability to debug
is much harder than it needs to be.
thanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Compile-Error-An-attempt-was-made-to-load-a-program-with-an-incorrect-format-tp4182810p5061989.html
