[mapguide-users] Compile Error: An attempt was made to load a program with an incorrect format.
Jackie Ng jumpinjackie at gmail.com
Mon Jun 24 21:03:05 PDT 2013
Are you debugging via local IIS or the built-in VS web server?
The latter is 32-bit (last I heard) and that is what causes problems trying
to run/debug 64-bit web applications.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Compile-Error-An-attempt-was-made-to-load-a-program-with-an-incorrect-format-tp4182810p5062001.html
