[mapguide-users] Only portions of a layer appears at some scales
Berg, James
James.Berg at stantec.com
Fri May 10 09:42:51 PDT 2013
Thank you for the response, Steve, but unfortunately, that hasn't helped. I'll remember that tip for future shp file problems, though.
I noticed something new, however. My map is validating with errors when I try to save it with this layer. Same thing happens when I try to validate the layer itself:
Error - Error_MapDefinition_ResourceRead: Library://[RESOURCE_PATH]/LayerName.FeatureSource could not be processed for spatial info:
The remote server returned an error: (559) MgFdoException.:
An exception occurred in FDO component.
Error occurred in Feature Source (Library://[RESOURCE_PATH]/LayerName.FeatureSource): FDO class 'LayerName' not found in schema.
Maybe I didn't notice because I tend to add layers to maps before I join them.
This makes it sound like a problem with the shp file itself to me. It still puzzles me why it would work in Autodesk MapGuide 6.5. If it is a problem with the shp file, I don't think there would be anything in Maestro I could do to fix it. Still, if anyone has an idea I would greatly appreciate it.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Steve G
Sent: Wednesday, May 08, 2013 1:45 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Only portions of a layer appears at some scales
Delete your shapefile index file (.idx). MapGuide will regenerate this.
-Steve
View this message in context: http://osgeo-org.1560.x6.nabble.com/Only-portions-of-a-layer-appears-at-some-scales-tp5052150p5052164.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
