[mapguide-users] Only portions of a layer appears at some scales
GordonL gordon.luckett at arrowgeomatics.com
Fri May 10 10:32:24 PDT 2013
I have noticed this happens if you map extents are not accurate.  I.e. one of
the Maximum Y are out to lunch (middle of Antarctica or something).
Check your map extents or re-generate them with Maestro.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Only-portions-of-a-layer-appears-at-some-scales-tp5052150p5052625.html
