[mapguide-users] How to change SRS in WMS provider?
Andrey Maraev
asmaraev at gmail.com
Thu May 23 00:37:53 PDT 2013
it works now! Thanks a lot
2013/5/23 Andrey Maraev <asmaraev at gmail.com>
> hi, Jackie!
> I just changed the all that was from EPSG:4326 to EPSG:32648
> in OgcWmsService.config.awd file like:
> <Define item="ReferenceSystems">
> <item>EPSG:32648</item>
> <item>CRS:32648</item>
> </Define>
> <Define item="SRS.WKT.map">
> <!-- This example fixes a problem with EPSG:21781 not
> finding the WKT for EPSG:21781 in the CS library.
> <translate
> from="EPSG:32648">PROJCS["UTM84-48N",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",500000.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",105.00000000000000],PARAMETER["scale_factor",0.9996],PARAMETER["latitude_of_origin",0.000],UNIT["Meter",1.00000000000000]]</translate>
> </Define>
> Sorry, but I am new in Mapguide. Maybe I forgot something else
> 2013/5/23 Jackie Ng <jumpinjackie at gmail.com>
>> In your WMS metadata in the resource properties, does the CRS have an
>> "EPSG:"
>> prefix?
>> - Jackie
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/How-to-change-SRS-in-WMS-provider-tp5054951p5055063.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> lernen,lernen und lernen
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130523/2d590979/attachment.html>
