[mapguide-users] MapGuide LineRule Label Text Change in RunTime
Jackie Ng
jumpinjackie at gmail.com
Thu May 23 03:44:40 PDT 2013
Are your primary (water_pipeline) and secondary sources (other_table) from
the same postgres db?
If so, just make a view that is a join of the two tables and style your
layer off of that view (that should appear as a Feature Class).
Or alternatively, make an Extended Feature Class in your Feature Source (the
one where water_pipeline comes from) that's a joins onto other_table and
style your layer off of that Extended Feature Class.
First option is the easiest but may produce un-selectable layers when based
off of a view. You would use Schema Overrides to fix the identity properties
of this view-based Feature Class (see:
http://themapguyde.blogspot.com.au/2010/08/using-fdo-schema-overrides.html)
The second option uses the Feature Join mechanism in MapGuide, which until
MGOS 2.4, was fraught with bugs and terrible performance in the most general
cases.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-LineRule-Label-Text-Change-in-RunTime-tp5055186p5055197.html
