[mapguide-users] Maestro4 RenderRuntimeMap different output from LocalNative and Http connection.
Jackie Ng jumpinjackie at gmail.com
Thu May 23 05:01:49 PDT 2013
If you want a baseline of truth, output an image using mapagent
GETDYNAMICMAPOVERLAYIMAGE with the appropriate
SET(VIEWSCALE/VIEWCENTERX/VIEWCENTERY/DISPLAYWIDTH/DISPLAYHEIGHT/DISPLAYDPI)
parameters (ie. What we would see in the AJAX/Fusion viewer) and compare
your two images against that.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Maestro4-RenderRuntimeMap-different-output-from-LocalNative-and-Http-connection-tp5055145p5055223.html
