[mapguide-users] What to write to "Server" slot on "Log on to a MapGuide Server" ?
Jackie Ng jumpinjackie at gmail.com
Fri May 24 01:32:05 PDT 2013
When you install MapGuide, you had two pre-defined choices:
 * Bundled install
 * IIS install
Assuming you picked default values, then:
 * Bundled install installs the Apache Web Server that listens on port 8008
 * IIS install integrates with your existing IIS Web Server that usually
listens on port 80
Thus when connecting with Maestro your server url is either:
 * Bundled install:
http://yourservername:8008/mapguide/mapagent/mapagent.fcgi
 * IIS install: http://yourservername/mapguide/mapagent/mapagent.fcgi
Username and password the credentials for the MapGuide author/administrator
account. The default Administrator account login is:
 * Username: Administrator
 * Password: admin
This should be all the information you need to be able to connect with
Maestro.
For a production installation, you are strongly advised to change the
Administrator password.
Hope that helps.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/What-to-write-to-Server-slot-on-Log-on-to-a-MapGuide-Server-tp5055461p5055469.html
