[mapguide-users] Can't open Mapinfo file in Maestro 4.0
Andrey Maraev asmaraev at gmail.com
Fri May 24 04:36:39 PDT 2013
Jackie , thank you. I'm appriciate your help) it works)
One mention, should I add a tab file to the right column Resource Data
Files after I apply your comments? Should I create an OGR connection for
each TAB file if I use more than one Mapinfo file or I can add the all
TAB-files in one of the  Resource Data Files column?
2013/5/24 Jackie Ng <jumpinjackie at gmail.com>
> Try %MG_DATA_FILE_PATH% (without the tab file name) as the DataSource
> Or you need to also set the ReadOnly parameter to TRUE
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/Can-t-open-Mapinfo-file-in-Maestro-4-0-tp5055530p5055532.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
lernen,lernen und lernen
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130524/7cadd0d2/attachment.html>
