[mapguide-users] Can't open Mapinfo file in Maestro 4.0
Jackie Ng jumpinjackie at gmail.com
Fri May 24 05:04:23 PDT 2013
OGR can connect to a directory of TAB files. Each TAB file is represented as
an individual feature class in MapGuide parlance.
Adding the tab files (and related files) as resource data means they are
embedded with the Feature Source. You should be able to embed multiple files
and access them all as %MG_DATA_FILE_PATH% is a special *directory*
Wherever the Feature Source goes (copy/move/delete/package), the data files
go with it.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Can-t-open-Mapinfo-file-in-Maestro-4-0-tp5055530p5055564.html
