[mapguide-users] MapGuide Maestro 5.0 RC1 and 4.0.5 maintenance release available
Zac Spitzer zac.spitzer at gmail.com
Wed May 29 17:49:15 PDT 2013
all you are still doing is downloading the file locally and then uploading
it.
You can already just paste the s3 url into a file open dialog and windows
will download the file for you
On Wed, May 29, 2013 at 9:43 PM, Andrew DeMerchant <
andrew.demerchant at gemtec.ca> wrote:
> Interesting - could you do it without coding (ie Maestro)?
> On 13/05/28 9:24 PM, Jackie Ng wrote:
> Under the hood, we're basically using the HttpWebRequest class whose input is
> now an unbounded System.IO.Stream instead of a man-in-the-middle
> MemoryStream.
> Although the latter does simplify code and we still use this code path if
> the file we're uploading is small enough, it is obviously an inefficient use
> of memory and an OOM trigger if we're trying to upload a file that's several
> GBs in size.
> So yes it's feasible. Our API just expects a System.IO.Stream. We don't care
> whether it's a file, in-memory object, or a download data stream from a
> remote cloud service/provider.
> - Jackie
> View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-Maestro-5-0-RC1-and-4-0-5-maintenance-release-available-tp5056482p5056592.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
>  [image: GEMTEC Limited] <http://www.gemtec.ca/>
> *Andrew DeMerchant*
> tel: 506.453.1025  /  toll-free: 1.877.243.6832
> fax: 506.453.9470
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130530/a3a6cfd7/attachment.html>
