[mapguide-users] MapGuide Maestro 5.0 RC1 and 4.0.5 maintenance release available
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu May 30 06:07:00 PDT 2013
Yes, you can do that in a windows dialog - but the question is, can I
use a url as a file path for a datasource (unmanaged) via Maestro? Also,
can I map a server alias using a url (rather than a local drive letter)?
I'm guessing the answer to that last one is a firm, no....though it
might be handy.
On 13/05/29 9:49 PM, Zac Spitzer wrote:
> all you are still doing is downloading the file locally and then
> uploading it.
> You can already just paste the s3 url into a file open dialog and windows
> will download the file for you
> On Wed, May 29, 2013 at 9:43 PM, Andrew DeMerchant
> <andrew.demerchant at gemtec.ca <mailto:andrew.demerchant at gemtec.ca>> wrote:
>     Interesting - could you do it without coding (ie Maestro)?
>     On 13/05/28 9:24 PM, Jackie Ng wrote:
>>     Under the hood, we're basically using the HttpWebRequest class whose input is
>>     now an unbounded System.IO.Stream instead of a man-in-the-middle
>>     MemoryStream.
>>     Although the latter does simplify code and we still use this code path if
>>     the file we're uploading is small enough, it is obviously an inefficient use
>>     of memory and an OOM trigger if we're trying to upload a file that's several
>>     GBs in size.
>>     So yes it's feasible. Our API just expects a System.IO.Stream. We don't care
>>     whether it's a file, in-memory object, or a download data stream from a
>>     remote cloud service/provider.
>>     - Jackie
>>     View this message in context:http://osgeo-org.1560.x6.nabble.com/MapGuide-Maestro-5-0-RC1-and-4-0-5-maintenance-release-available-tp5056482p5056592.html
>>     Sent from the MapGuide Users mailing list archive at Nabble.com.
>>     _______________________________________________
>>     mapguide-users mailing list
>>     mapguide-users at lists.osgeo.org  <mailto:mapguide-users at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
>     GEMTEC Limited <http://www.gemtec.ca/>
>     *Andrew DeMerchant*
>     tel: 506.453.1025  /  toll-free: 1.877.243.6832
>     fax: 506.453.9470
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> +61 405 847 168
*Andrew DeMerchant*
fax: 506.453.9470
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130530/5040ce12/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130530/5040ce12/attachment.png>
