[mapguide-users] Fusion doesn't sync the two Maps!
benjanmin
erictsn at gmail.com
Thu May 30 01:39:40 PDT 2013
Hi All
I have created a fusion layout and linked two difference map definitions.
The two map def uses the same projection. I can switch the two maps in
fusion viewer without problem. The problem is the current viewing location
cannot sync, it was shifted. :(
Anyone know how to do? Thanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Fusion-doesn-t-sync-the-two-Maps-tp5056897.html
