[mapguide-users] [MapGuide 2.4] Web .Net API SetResource failed 1 to 2 times
Zac Spitzer zac.spitzer at gmail.com
Thu May 30 19:32:14 PDT 2013
I'd guess the session expired?
On Thu, May 30, 2013 at 9:22 PM, Rémy Gourrat <rgourrat at ag-carto.fr> wrote:
>  Hello,****
> I have a .net web api  wich edit feature source definition****
> At the end of the function, I update the new feature source definition by
> this code in the session repository****
> // Chargement du String xml dans une variable type MgByteSource  ****
>                                MgByteSource contentByteSource = new
> MgByteSource(encodedDefinition, encodedDefinition.Length);****
>                                //Ecriture du nouveau FeatureSourceID dans
> la Session: en lieu et place du précédent s'appuyant sur Library****
>                                String str_NewFeatureSourceId =
> FeatureSourceListElem.Replace("Library:","Session:" + sessionId);****
>                                MgResourceIdentifier new_MgfeatureSourceId
> = new MgResourceIdentifier(str_NewFeatureSourceId);****
>                                // Sauvegarde de la ressource avec la
> nouvelle définition****
>                                ag_ResourceService.SetResource(new_MgfeatureSourceId,
> contentByteSource.GetReader(), null);****
> During many hours it’s running very very  well ****
> And suddenly it’s failing, and after few minutes or hours or enable the
> iis trace it’s running well again !****
> But when it failed, my Exception Catch code is not executing in my function
>                 catch (MgException mge)****
>                                errMsg = mge.GetExceptionMessage() + "\n" +
> mge.GetDetails();****
>                                ag_PrintMessage("ag_proc.aspx : " +
> "ag_SetSRSFeatureSource : ","Erreur ! Exception levée par Catch " + errMsg);
> But I have a message in the Errors.log :****
> <2013-04-26T12:12:16>
> 2084                                      Anonymous****
>  Error: Permission denied to resource:
> Session:c3b53a1a-ae59-11e2-8000-00155d2d5706_en_MTI3LjAuMC4x0AFC0AFB0AFA//Ag
> Base/2 - Calques/ASSC_LDE/LDE_A_COLLEC_EP.LayerDefinition****
>  StackTrace:****
>   - MgResourceServiceHandler.ProcessOperation() line 80 file
> c:\mg-2.4-x64\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
>   - MgOpSetResource.Execute() line 103 file
> c:\mg-2.4-x64\mgdev\server\src\services\resource\OpSetResource.cpp****
>   - MgServerResourceService.SetResource() line 1064 file
> c:\mg-2.4-x64\mgdev\server\src\services\resource\ServerResourceService.cpp
>   - MgRepositoryManager.SetResource() line 563 file
> c:\mg-2.4-x64\mgdev\server\src\services\resource\RepositoryManager.cpp****
>   - MgRepositoryManager.AddResource() line 536 file
>   - MgResourceContentManager.AddResource() line 183 file
> c:\mg-2.4-x64\mgdev\server\src\services\resource\ResourceContentManager.cpp
>   - MgResourceContentManager.PutDocument() line 624 file
>   - MgSessionRepositoryManager.CheckPermission() line 238 file
> c:\mg-2.4-x64\mgdev\server\src\services\resource\SessionResourceContentManager.cpp
>   - MgSessionResourceContentManager.CheckPermission() line 235 file
> c:\mg-2.4-x64\mgdev\server\src\services\resource\SessionResourceContentManager.cpp“
> Somebody have an explanation for this ? is there a specific concept that I
> don’t understand ?****
> Thanks****
> Rémy****
>  AG-Carto - Bayonne
> View this message in context: [MapGuide 2.4] Web .Net API SetResource
> failed 1 to 2 times<http://osgeo-org.1560.x6.nabble.com/MapGuide-2-4-Web-Net-API-SetResource-failed-1-to-2-times-tp5056933.html>
> Sent from the MapGuide Users mailing list archive<http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html>at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130531/77c997e3/attachment.html>
