[mapguide-users] [MapGuide 2.4] Web .Net API SetResource failed 1 to 2 times
Rémy Gourrat
rgourrat at ag-carto.fr
Thu May 30 04:22:38 PDT 2013
Hello,
I have a .net web api wich edit feature source definition
At the end of the function, I update the new feature source definition by this code in the session repository
// Chargement du String xml dans une variable type MgByteSource
MgByteSource contentByteSource = new MgByteSource(encodedDefinition, encodedDefinition.Length);
//Ecriture du nouveau FeatureSourceID dans la Session: en lieu et place du précédent s'appuyant sur Library
String str_NewFeatureSourceId = FeatureSourceListElem.Replace("Library:","Session:" + sessionId);
MgResourceIdentifier new_MgfeatureSourceId = new MgResourceIdentifier(str_NewFeatureSourceId);
// Sauvegarde de la ressource avec la nouvelle définition
ag_ResourceService.SetResource(new_MgfeatureSourceId, contentByteSource.GetReader(), null);
During many hours it's running very very well
And suddenly it's failing, and after few minutes or hours or enable the iis trace it's running well again !
But when it failed, my Exception Catch code is not executing in my function
catch (MgException mge)
errMsg = mge.GetExceptionMessage() + "\n" + mge.GetDetails();
ag_PrintMessage("ag_proc.aspx : " + "ag_SetSRSFeatureSource : ","Erreur ! Exception levée par Catch " + errMsg);
But I have a message in the Errors.log :
<2013-04-26T12:12:16> 2084 Anonymous
Error: Permission denied to resource: Session:c3b53a1a-ae59-11e2-8000-00155d2d5706_en_MTI3LjAuMC4x0AFC0AFB0AFA//Ag Base/2 - Calques/ASSC_LDE/LDE_A_COLLEC_EP.LayerDefinition
StackTrace:
- MgResourceServiceHandler.ProcessOperation() line 80 file c:\mg-2.4-x64\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
- MgOpSetResource.Execute() line 103 file c:\mg-2.4-x64\mgdev\server\src\services\resource\OpSetResource.cpp
- MgServerResourceService.SetResource() line 1064 file c:\mg-2.4-x64\mgdev\server\src\services\resource\ServerResourceService.cpp
- MgRepositoryManager.SetResource() line 563 file c:\mg-2.4-x64\mgdev\server\src\services\resource\RepositoryManager.cpp
- MgRepositoryManager.AddResource() line 536 file c:\mg-2.4-x64\mgdev\server\src\services\resource\RepositoryManager.cpp
- MgResourceContentManager.AddResource() line 183 file c:\mg-2.4-x64\mgdev\server\src\services\resource\ResourceContentManager.cpp
- MgResourceContentManager.PutDocument() line 624 file c:\mg-2.4-x64\mgdev\server\src\services\resource\ResourceContentManager.cpp
- MgSessionRepositoryManager.CheckPermission() line 238 file c:\mg-2.4-x64\mgdev\server\src\services\resource\SessionResourceContentManager.cpp
- MgSessionResourceContentManager.CheckPermission() line 235 file c:\mg-2.4-x64\mgdev\server\src\services\resource\SessionResourceContentManager.cpp"
Somebody have an explanation for this ? is there a specific concept that I don't understand ?
Thanks
Rémy
AG-Carto - Bayonne
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-2-4-Web-Net-API-SetResource-failed-1-to-2-times-tp5056933.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130530/3bc0fc16/attachment.html>
