[mapguide-users] Fusion legend performance fixes in the future?
amorsell andy.morsell at autodesk.com
Fri Nov 1 22:37:39 PDT 2013
Hi Jackie,
Thanks for the reply.  I am using AIMS 2013 with IE 8 and that is not what
I'm seeing.  Using Fiddler, I can see up to 300 OPERATION=GETLEGENDIMAGE
calls in a row upon zooming in to a level where all layers are available.
Each change in scale factor results in a re-request of each legend image.
Here's a typical request:
GET
/mapserver2013/mapagent/mapagent.fcgi?OPERATION=GETLEGENDIMAGE&SESSION=a4daacfe-437a-11e3-8000-005056945141_en_MTI3LjAuMC4x0AF20AF10AF0&VERSION=1.0.0&SCALE=4622336.17439434&LAYERDEFINITION=Library%3A%2F%2FGVEA_AIMS%2FLayers%2FLand%2FGVEA%20Offices.LayerDefinition&THEMECATEGORY=0&TYPE=1&CLIENTAGENT=Fusion
The legend widget uses the MapGuide.js getLegendImageURL function which in
turn is using the GETLEGENDIMAGE operation.
Is there something that I'm missing?
Thank you,
Andy
View this message in context: http://osgeo-org.1560.x6.nabble.com/Fusion-legend-performance-fixes-in-the-future-tp5087026p5087063.html
