[mapguide-users] Mapguide 2.5 problem connecting WFS 1.1.0
Steve G stevenlgolden at gmail.com
Wed Nov 20 10:18:33 PST 2013
I've been able to create a feature source using the OSGeo.WFS provider and
create a vector layer from the feature source (saved both of these).  I have
used a theming method based on attributes of the WFS feature.  Previewing
the feature source (data connection) doesn't display much of anything (only
thing displayed is Schema:XXXXXX vs. all of the feature classes) and
previewing the layer (both in the local map viewer or not) displays the
layer in the legend but fails to properly display the layer in the map.
However, if I add the layer to a map definition, the layer displays
properly.  The one problem that I have encountered is being able to select
features of the WFS layers (labeling, theming, and tooltips work
properly...I just can't select any of the features; previously reported
here:
http://osgeo-org.1560.x6.nabble.com/WFS-Primary-Key-problem-tp5080454p5082495.html).
What are the connection parameter properties that you are using?  Perhaps
you can post the WFS server that you are trying to connect to (if public).
Steve G
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-2-5-problem-connecting-WFS-1-1-0-tp5090232p5090260.html
