[mapguide-users] switching to Maestro 5 API
Jackie Ng
jumpinjackie at gmail.com
Sun Nov 24 20:52:49 PST 2013
The Maestro SDK contains everything you need to build an application on top
of the Maestro API:
- The Maestro API assemblies
- The full API reference + basic developer's guide in a CHM document
- Some desktop/web sample applications using the Maestro API
- A ProviderTemplate utility to build your own LocalNative connection
provider that wraps your specific version of the official .net MapGuide API.
You can download the Maestro SDK from the same download page as Maestro
itself: http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
To answer your question specifically:
Use the CreateCommand() of the IServerConnection to create a IDeleteFeatures
command:
public void ClearDataSource(IServerConnection conn, String
dataSourceId, String featureName)
IDeleteFeatures deleteCmd =
(IDeleteFeatures)conn.CreateCommand(CommandType.DeleteFeatures);
deleteCmd.FeatureSourceId = dataSourceId;
deleteCmd.ClassName = featureName;
deleteCmd.Filter = "ID >= 0";
int nDeleted = deleteCmd.Execute();
Note that support for IDeleteFeatures varies on the implementation of
IServerConnection. For example, the HTTP one that wraps the mapagent won't
support CRUD operations, but the ones that wrap the official MapGuide API
and mg-desktop do support CRUD operations. You can programmatically check
support for such commands via the capabilities of the IServerConnection
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/switching-to-Maestro-5-API-tp5090710p5090931.html
