[mapguide-users] Server down when editing webconfig.ini
Jackie Ng jumpinjackie at gmail.com
Mon Nov 25 00:00:55 PST 2013
Yeah, make sure there's no BOM marker in the file. It will probably cause
problems.
As a mental checklist, if you set DefaultMessageLocale = sv in
webconfig.ini/serverconfig.ini, then you should have the following files
present (with all strings translated):
 - Server\Resources\mapguide_sv.res
 - Web\www\mapagent\Resources\mapguide_sv.res
 - Web\www\fusion\text\sv
 - Web\www\fusion\text\sv.json
 - Web\www\localized\sv
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Server-down-when-editing-webconfig-ini-tp5090597p5090942.html
