[mapguide-users] Server down when editing webconfig.ini
Fredrik Ohlsson 77fredrik at gmail.com
Sun Nov 24 23:35:51 PST 2013
I didn't know about 'Web\www\mapagent\Resources\mapguide_en.res so I'll try
that also!
I have translated these files in new filenames (en->sv)
Server\Resources\mapguide_en.res
Web\www\fusion\text\en & en.json
Web\www\localized\en
Im using Notepad++ and the thing that says 'Convert to UTF-8' in the
Encoding menu. Maybe I should use 'Convert to UTF-8 without BOM' ?
2013/11/25 Jackie Ng <jumpinjackie at gmail.com>
> Check the following:
>  a) Do you have your translated strings in a mapguide_YOURLANGUAGECODE.en
> file under Server\Resources and Web\www\mapagent\Resuorces ?
>  b) Have you saved webconfig.ini with the correct encoding?
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/Server-down-when-editing-webconfig-ini-tp5090597p5090932.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20131125/d0776ae7/attachment.html>
