If you are using IE then try the torn page icon to the far right of the address bar. Click it to enable/disable compatibility mode. See if that helps. Hans... -- View this message in context: http://osgeo-org.1560.x6.nabble.com/Missing-icons-using-Fusion-tp5081769p5081771.html Sent from the MapGuide Users mailing list archive at Nabble.com.
