[mapguide-users] Mapguide 2.6 Coordinate Tracker widget
Jackie Ng
jumpinjackie at gmail.com
Thu Oct 10 08:15:00 PDT 2013
Add a <Projection> element under the <Extension> element for each coordinate
system you want your mouse coordinates to be represented in. The
<Projection> element must be an EPSG code.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-2-6-Coordinate-Tracker-widget-tp5082832p5082901.html
