[mapguide-users] Map Menu, i can't pan after select an another map
Jackie Ng jumpinjackie at gmail.com
Fri Oct 11 07:05:08 PDT 2013
If you have installed the Fusion 2.6 preview build, please check if this
issue has been resolved or still persists.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Map-Menu-i-can-t-pan-after-select-an-another-map-tp5070445p5083108.html
