[mapguide-users] Mapguide 64 bit and ODBC 64
Andrew DeMerchant andrew.demerchant at gemtec.ca
Tue Oct 22 04:51:14 PDT 2013
I'd been trying to decided if this was the version that I should finally
make the x64 switch, but it sounds like it's not, I guess. Here's hoping
that someone has the time to delve into this and see if it can be fixed
for the next release! Have you filed a bug for this officially?
On 13/10/21 5:30 PM, gom wrote:
> It has taken some time to get here but I can say that I was able to install
> and configure a 32 bit version of Mapguide 2.51 and the performance of the 3
> affected data sources is double or better.  That is to say, using 32 bit
> Mapguide and 32 bit Access ODBC driver works more than twice as fast as 64
> bit.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-64-bit-and-ODBC-64-tp5082718p5084884.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
GEMTEC Limited <http://www.gemtec.ca/>
*Andrew DeMerchant*
tel: 506.453.1025  /  toll-free: 1.877.243.6832
fax: 506.453.9470
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20131022/dae8209a/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20131022/dae8209a/attachment.png>
