[mapguide-users] Mapguide 64 bit and ODBC 64
Martin Morrison martin.morrison at edsi.com
Tue Oct 22 05:05:40 PDT 2013
Perhaps the solution may be to use SQL Server, Oracle or MySQL.  Access hasn't been a super big upgrade on Microsoft's plate.
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew DeMerchant
Sent: Tuesday, October 22, 2013 7:51 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Mapguide 64 bit and ODBC 64
I'd been trying to decided if this was the version that I should finally make the x64 switch, but it sounds like it's not, I guess. Here's hoping that someone has the time to delve into this and see if it can be fixed for the next release! Have you filed a bug for this officially?
On 13/10/21 5:30 PM, gom wrote:
It has taken some time to get here but I can say that I was able to install
and configure a 32 bit version of Mapguide 2.51 and the performance of the 3
affected data sources is double or better.  That is to say, using 32 bit
Mapguide and 32 bit Access ODBC driver works more than twice as fast as 64
bit.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-64-bit-and-ODBC-64-tp5082718p5084884.html
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
[GEMTEC              Limited]<http://www.gemtec.ca/>
Andrew DeMerchant
tel: 506.453.1025  /  toll-free: 1.877.243.6832
fax: 506.453.9470
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20131022/839c2f71/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20131022/839c2f71/attachment.png>
