[mapguide-users] Mapguide 64 bit and ODBC 64
Gord McKenzie
gord.mckenzie at canam.com
Tue Oct 22 06:13:27 PDT 2013
I have tried to adjust ODBC settings, definitely not a tracing issue. Access is my only choice at this moment but I am open to SQL Server as we use it for some other things. I have not filed any bug reports. I have only managed to cobble together a very basic test. I'm not personally confident that my test is definitive enough to say for sure that this is a bug.
Interesting that Microsoft is planning on phasing out OLE DB in favour of ODBC for SQL Server. http://tdwi.org/Articles/2012/03/27/SQL-Server-2012-End-of-Era.aspx?Page=1
Thanks for the feedback.
Gordon McKenzie
GIS Coordinator
[cid:image004.jpg at 01CECEF6.333C2760]
T: 403.269.8887 / 1.800.478.6162
E: Gord.Mckenzie at canam.com canam.com<http://www.canam.com/>
900, 340 - 12th Avenue SW Calgary, AB T2R 1L5
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew DeMerchant
Sent: Tuesday, October 22, 2013 6:21 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Mapguide 64 bit and ODBC 64
I don't know that that's a solution - it's definitely a workaround though. I'm not sure if you can set OBDC settings/options from MGOS, but if you can, you might try this (in a nutshell, disabling "when to trace"):
http://answers.microsoft.com/en-us/office/forum/office_2010-access/my-solution-to-access-being-slow-with-odbc/a5a6522f-a70f-421e-af1b-48327075e010
I guess the question would be, is this an MGOS problem, or is it an ODBC (MS) problem? If changing the setting above makes the difference, then we've got our answer.
On 13/10/22 9:05 AM, Martin Morrison wrote:
Perhaps the solution may be to use SQL Server, Oracle or MySQL. Access hasn't been a super big upgrade on Microsoft's plate.
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA 24018
540.345.1410
gis.edsi.com
From: mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew DeMerchant
Sent: Tuesday, October 22, 2013 7:51 AM
I'd been trying to decided if this was the version that I should finally make the x64 switch, but it sounds like it's not, I guess. Here's hoping that someone has the time to delve into this and see if it can be fixed for the next release! Have you filed a bug for this officially?
On 13/10/21 5:30 PM, gom wrote:
It has taken some time to get here but I can say that I was able to install
and configure a 32 bit version of Mapguide 2.51 and the performance of the 3
affected data sources is double or better. That is to say, using 32 bit
Mapguide and 32 bit Access ODBC driver works more than twice as fast as 64
bit.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-64-bit-and-ODBC-64-tp5082718p5084884.html
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
[GEMTEC Limited]<http://www.gemtec.ca/>
Andrew DeMerchant
tel: 506.453.1025 / toll-free: 1.877.243.6832
fax: 506.453.9470
Andrew DeMerchant
fax: 506.453.9470
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20131022/1a1511db/attachment.html>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20131022/1a1511db/attachment.png>
Type: image/jpeg
Desc: image004.jpg
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20131022/1a1511db/attachment.jpg>
